A new build of 11.1_5761 is available and ready for download at https://transfer.rossvideo.com/f/2820a1bc0638ea4d
Changes in this build:
[implemented] Text Format support in RSS/HTTP Datalinq
[improved] added warning for effects in Tessera Master
[improved] XPression Streamdeck plugin now uses TCP Keep alive
[improved] added warnings and disabled unsupported transitions in Tessera Master
[fixed] clicking on the layer column in Remote Sequencer when the value is the channel default or the template default and then clicking away from it would set the layer to 0
[fixed] video clips played on multiple Tessera destinations that were not previously online could be out of sync (introduced in build 5755)
[fixed] HTML5 Plugin would crash on every graphic edit unless the automation was set to MosArt in the Gateway (introduced in build 5760)
[fixed] projects would fail to unload via MOS (Introduced in 11.1.5758)
