I have a tab container with 5 five tabs.
I am trying to set a variable when seleccting the differents tabs.
I think I should use the onchange attribute, but I am not declaring properly.
Anyone has an example?
Best regards,
Eduardo
I was trying to figure this out, too, and finally got something working. Adding an ogscript element to the meta section with the attribute handles=“onchange” is half the puzzle. You also need to added the targetid attribute with the id of the tab you want to follow.
//ogScript code Also, some other useful items from the manual:Current tab index is: this.getSelectedIndex()
Current tab name is: this.getTitleAt(this.getSelectedIndex() )
