We have been supplied with a media wipe(tga squence) that is a small bar that wipes from left to right of screen
The new background needs to appear as the wipe passes across.
This leaves me no full frame cut point. How could i achieve this.
Thanks Forum
Hi Peter,
The only way to do this is to build the effect using custom Controls. You would not be able to use the standard Media wipe button and instead have to put the animation into a regular ME keyer, then time a wipe to match it underneath. Its actually not that difficult to do as long as the Animation moves linearly across the screen.
If you need help with creating this feel free to contact me directly.
Nigel
