API from Rundwon Creator
I was wondering if it is possible to get information from rundown creator through API into dashboard and if it possible how? I have no experience with coding/programing. And when i get the information i can set up some logics to trigger actions like CG(xpression) and lightcues on our ma dot2.
Big thanks for any help on this topic
Info on the API
https://rundowncreator.com/api/
I got the APIkey, Token and URL but i dont know how to get the information into dashboard.
This appears to be a fairly simple restful API.
What you would do is create a function to process the content once it has been downloaded and then use ogscript.asyncPost to request the information from the server.
function handleResults(resultData)
if (resultData == null)
ogscript.debug(“NO DATA”);
else
var resultsAsObject = JSON.parse(resultData);
//WORK WITH THE JSON OBJECT HERE
ogscript.asyncPost(‘PUT_YOUR_URL_HERE’, null, handleResults);
Okay, Thanks! I’m new to coding and have no experience. Where should I input the commands I want to request from Rundowncreator to get the information i want. Like the command “getRundown”. Could you give me an example of how this is solved?
Information:
URL: https://rundowncreator.com/luc/API.php
?APIKey=Even
&APIToken=o0YLzKCLkKmb2egv1Ti5HYv9oQbISI
&Action=getRundowns
In that scenario, your URL would be:
https://rundowncreator.com/luc/API.php?APIKey=Even&APIToken=o0YLzKCLkKmb2egv1Ti5HYv9oQbISI&Action=getRundowns
It is hard to tell you where you should put it without knowing what exactly you’re trying to do. Generally, we would recommend creating a function to fetch the rundown and putting it into an tag at the top of your panel… but without knowing what you’re looking to do with the results of fetching the rundown, it’s a bit difficult to advise beyond that.
I understand!
I’m just testing if i can build my own rundown and getting all the info from rundowncreator.
Yes, it will be some coding/scripting but i think it will help me get a better understanding and get experience.
In that case, I would recommend putting your “handleResults” function in an tag near the top of your file.
You can then have a button or an that calls the functions in your .
Your handler can run through the returned JSON object for the rundown and put them in parameters you can see on screen.
Here is a fairly simple example of how you would interact with the JSON object:
params.RundownID params.Title function handleResults(resultData) { if (resultData == null) { ogscript.debug("NO DATA"); } else { var resultsAsObject = JSON.parse(resultData); var ids = []; var titles = []; for (var i = 0; i < resultsAsObject.length; i++) { ids.push(resultsAsObject[i]["RundownID"]); titles.push(resultsAsObject[i]["Title"]); }
    //We need to make sure we always have at least one element in a parameter
    if (ids.length == 0)
        ids.push("");
        titles.push("");
    params.setAllValues('params.RundownID', ids);
    params.setAllValues('params.Title', titles);
function fetchRundown()
ogscript.asyncPost(‘https://rundowncreator.com/luc/API.php?APIKey=Even&amp;APIToken=o0YLzKCLkKmb2egv1Ti5HYv9oQbISI&amp;Action=getRundowns’, null, handleResults);
/! block id=1000 !/
fetchRundown()
/!!97f7d234533212934b6c5e069b1d31b0!!/
/! block id=1001 !/
fetchRundown()
/!!2cd1be6cfe34db06a453cd5214acd084!!/
Hey! Addison from Rundown Creator here. This thread is a little old, but I thought I’d chime in to let you know we just launched some new XPression integration that you might be interested in. You can learn more about it here, but basically what it allows you and your team to do is insert information for lower-thirds, fullscreen graphics, over-the-shoulder boxes, and more into Rundown Creator, then play them out with a single key press from the XPression sequencer. It’s all real-time, so any changes made in Rundown Creator show up instantly in XPression. It works with all versions of XPression and doesn’t require any special options. Happy to answer any questions you might have!
