Hello Dashboard Experts,
Is there any way to add a confirmation box to Dashboard which will ask “Are You Sure?” when a user hits a button? I am making a “Reset Control Room” button in Dashboard which will send the correct commands and GPI triggers to reset the switcher, router, multiviewers, etc to a default state. I want to protect this button so people don’t click on it by mistake during a show.
I’m not sure if there’s anything like that, but why don’t you use tabs to hide it in a different tab within your custom layout? So have one tab with all your other buttons, then an “Advanced” tab with the “Reset Control Room” button in it.
Your best bet is to make a button parameter of type “Prompt Button”. This will cause a confirmation prompt before the task is executed.
You can further customize the prompt by specifying a “configuration attribute” called w.changeprompt
Also of interest, you can add w.changeprompt to a number of parameters to force a confirmation before changing a value… but for what you’re talking about, a “button-prompt” parameter is the correct type.
Do you want to reset everything?
Reset World
Reset World
ogscript.debug("RUN SCRIPT!");
Hi, the code snippet above to make this work isn’t showing up for me. Can you repost? Trying to make a similar confirmation prompt.
Hi Gene.
I do have the original example - it appears that something has happened to the posted code when we updated the Community software.
Here is a similar example that shows how to add a change prompt to a parameter.
Value 1
Value 2
Value 3
Value 4
Value 5
Value 6
Are you sure you want to do this?
Thanks James, I see it now!
