Hey,
Pretty random questions but…
I was wondering if there was a way to create a shortcut to get to the audio fader map in the installation menu? If this isn’t possible on the Acuity itself could Dashboard tell the switcher to go to that menu?
Thanks for any responses.
This is not possible. Sorry.
#Acuity
That’s what I was guessing, but figured I’d ask thanks.
#Acuity
I use an old Vision switcher and on that switcher I use macros to remap my audio faders as needed during shows- it’s super simple.
It doesnt get me to the “setup list” but it gets me the preprogrammed sources I need.
#Acuity
Would you mind posting an example of the macro to remap the audio faders?
#Acuity
The macro is only 2 lines… ASSIGN FADER, END.
Go to your CC menu and select a macro register to record to.
Start recording.
(F4) insert special
(more) (F6) audio fader. Within the audio fader sub menu there will be clear choices. You want function=assign fader, from there you can choose the fader you want to modify and the source(s) you want to apply to that fader.
(F1) insert.
Thats it!
#Acuity
Really appreciate this!
#Acuity
