I’ve seen recently a new tumbnail call subtitution table configuration in dashboard, I’ve tried to test it : by exemple saying to the mini-me1 to replace cam 1 by cam3 in minime1 when cam1 is to program… but i’m not able to do it, i dont see any difference. Maybe i should do a auto-follow somewhere beetween Minime1 and Me2 but i dont know also how to do it. Somebody can help me? I’m running in 2me 4mini-me mode
Hi Simon,
Currently there is no implementation of the Sub Table working outside of MultiScreens.
You could setup 2 MiniMEs to be part of a MSscreen and then you are able to setup full subs – including the same source you want on both so that the MiniME does a tile not a “scale”.
Ok thanks Les,
and can you tell me if there is a way to do an auto-follow (link 2 Me together) so that i can build 2 different cleanfeed as one mini-me( or Me1) follow the other
You can’t link MEs together currently. Only MiniMEs. By assigning them to a MultiScreen but then doing full sub table.
Might be better if we talk on a phone tomorrow??
