I am new to scripting and have been trying to tech myself Visual Basic but I need some help trying to make this work. Essentially I am working on a basketball score bug and I want it to play different animations depending on how much a certain text object increases. I have it set up right now to only play a single animation every time a text objects changes/updates. My script looks like this (for reference I have two text objects each for HOME and AWAY, one hidden and one visible, it is Datalinqd to Daktronics):
On the scene itself:
OnOnline
Dim scr as xpTextObject
scene.GetObjectByName(“AW ScrText” , scr)
scene.GetObjectByName(“Aw Score” , txt)
txt.Text = scr.Text
On the hidden script (this example is only for the away score):
OnSetText
Dim dir as xpSceneDirector
scene.GetSceneDirectorByName(“AW Score” , dir)
dir.PlayRange(0,60)
I want to change this to play a simple animation when the hidden text increases by 1 or 2 (For a free throw or field goal in basketball), and then play a different more complicated animation when it increases by 3. I know this is probably simple I am just in the process of learning so thank you for any help you can provide!
