Bug not inserting half or final
Hey has anyone had issues with pressing halftime or Final on dashboard and it just appearing blank?
Did anyone figure out how to fix it?
Hi Cristian
This sounds like an issue with a particular DashBoard Custom Panel. Do you know which devices it is trying to control? Are you able to post any code snippets from it?
James,
So I’m using a college basketball bug and when I click half or final the clock middle part where it should say Half or Final goes blank. Is this the code snippet you’re referring to?
Hi Christian
Do you mean the ‘clock middle part’ on your XPression graphic? The only thing this button is doing is setting a parameter value and triggering 3 XPression RossTalk Smart GPIs. If you are using XPression DataLinq to put the value of the Qtr_Text_Rep parameter onto your graphic, I would verify in your DataLinq manager that the value is still correct after the button is pressed and, if it is, take a closer look at what scripts in your XPression Project are tied to those GPI triggers.
