button not display any name on my carbonite minime fcfs
That is going to be something with the Contrast settings being off…
I don’t have a Carbonite Panel to be able to find the exact order though…
  • I think it is going to be Press Menu (looks like you are on that in the first picture..)
  • Press the Bottom Row second from Left Mnemonic Menu Button in the upper right of the panel under the Carbonite Logo
  • Click on the “third” Knob in the menu – should say Mnemonics..
  • you should now have the menu for adjusting the brightness and contrast.
dear les,
The name of the screen is not visible even if the brightness contrast is increased or decreased
You need to contact tech support at this point so that they can help you over the phone.
https://support.rossvideo.com/hc/en-us?_gl=1*789e0w*_ga*NjA4NDkzOTcwLjE2MDQ2MTI0NTg.*_ga_H7SG1QNZ8K*MTY4NDc4ODM4Ni40OC4wLjE2ODQ3ODgzODYuNjAuMC4w*_ga_6FCGERH8B4*MTY4NDc4ODM4Ni40ODIuMC4xNjg0Nzg4Mzg2LjYwLjAuMA..
