On the Vision switcher there is a way to save a backup of the entire system to a USB drive. Is there any way to do this on the Carbonite switcher?
Lara, indeed there is. It’s just the same as Vision. In the menu area there are Save and recall buttons that do exactly that and all saves are stored on the USB device that is plugged into the frame.
Lara:
If you are saving your show for the first time, it will be saved as a SET (your choice 0-9)… You can then disconnect the USB from the Carbonite and use a PC to rename your saved set to any name you want.
To load a show – Select LOAD then scroll through the USB to find the show name or set number you saved it to… You can recall all or you can recall individual parts of your show like most switchers… IE.. Config, Emem.. etc
IF by chance you do not see the USB just disconnect and reconnect it to the Carbonite frame.
Hey Team,
I was just saving everything onto a USB Stick but realised that it doesn’t save what you have assigned to the 8 AUX ports. Is there a way to save these to the USB or not yet. I might just have to set up a Custom Control to set them all up.
Regards,
Jonathan
When your saving memories or the RState you have to include the Aux Buses in your recalls.
Watch the memories tutorials for either Graphite or Carbonite to cover this.
