Carbonite Black Solo - design question related to multiple outputs
We are considering this product for a new implementation for a house of worship. We would like to be able to direct an inhouse production with 3 screens and also a separate stream output.
"‹Does the solo support have a stream broadcast that would for the most part mirror the main inhouse broadcast but with added things like pre, post, and mid video’s, separate control over display of lower third from main in displays, etc. further, can it control the 3 inhouse screens and say a stream output as separate controllable outputs - for example, playing a video on 1, static image on 2, IMAG with lower third on 3, IMAG with or without on stream (output 4). Thanks!
The Solo has 2 MiniME and 1 ME that would allow you to have effects and transitions plus layers of video. There are also Aux Buses so you could send different video to each however since you would only have 3 Total capable of a transition an layers.
