Carbonite Black Tallies to Ultrix
After a reset, my Carbonite black switcher lost the configuration used to communicate the TALLYs with the Ultrix.
This switcher has been upgraded to version 15.6.1.19113. I can no longer find the menus used to configure the TSL_UMD protocol, which is used to communicate tally status to the image mosaic managed by the Ultrix.
What I do to configure
System —>Device Config —> Add new —>Serial tally —>Add 0-TSLumd_1.0 —>confirm
In my memory, on version 12 of the switcher, you could set the communication port used. I can’t find this part of the menu.
Can you tell me what settings I need to make to configure this gateway with the ultrix?
Thank’s
Sylvain
The Manual is available directly on the website in searchable HTML form:
https://help.rossvideo.com/carbonite-02/?_gl=1*vrbsmh*_ga*NTUyMTAxNDIzLjE2Nzk1NzcxMjU.*_ga_H7SG1QNZ8K*MTY5MzQyMzQ1My41My4xLjE2OTM0MjM0NjAuNTMuMC4w
The link to the TSL Device configuration can be found here:
https://help.rossvideo.com/carbonite-device/Topics/Devices/UMD/TSL.html#topic.tsl
I am guessing you are adding to the Serial Port not adding a new device and selecting a IP “SLOT” for the device.
Thank you less for your reply,
it’s the Next button that was missing in my setup procedure. I was able to set the IP address and port value.
Everything is working properly now.
Sylvain
Thanks for following up!
