Carbonite Ultra/Touch Drive. I would like to use a CC to change a MV clock from time of day to a preset countdown. After a Hold, start the countdown, then have it revert back to time of day once the countdown is over. Maybe with some background color change as the clock mode changes. Wouldn’t this be cool! It looks like all the commands needed to do that are in the editor but I seem to be missing something.
I have been able to get a countdown clock to start when built as a stand-along CC. What I have not been able to do is change the clock mode between time of day and countdown either as a stand-alone or part of another CC. Another oddity is the MV Clock (Preset Color) CC command works in the editor when I click Run Event, but does not work when I run the CC from the TD panel.
I have tried constructing using Create / Edit Event (Multiviewer/Clock/MV Clock Mode/MV IO 1/System (or Countdown) as well as putting the editor in Record mode and using Dashboard. I also tried adding 10f pauses between events to give Carbonite time to think.
This is an awesome feature that I hope to use. Am I the only TD that likes to have cool effects even in their multiview?
Carbonite 6.6.1.7053 / Touch Drive 1.4 build 187
