I am trying to figure out if there is a way that I can apply some sort of command to cut a keyer on a media transition. Currently on my replay wipes we have the scorebug stay on, but I would like to either remove the scorebug or attach a ross talk command to call up a specific replay sponsor. Is there a way to do this where it stores the command within the media wipe, or would I be better of creating a custom control?
I just upgraded to Version 12 and am running Dashboard 8.0.
Where is the MediaWipe coming from? Is it from the switcher? Are you running this as a Custom Control or manually? What keyer is your Score Bug on – Where would you be getting the Sponsor from – Internal/external which keyer?.
Media wipe is coming from the media cache of a USB so yes from the Switcher. It would be triggered manually. It would be the 3rd keyer. The sponsor is just a thought, right now I would just like to remove it when we use that specific wipe and then if possible bring it back in on the return wipe.
When you go to do the wipe Select BKGD and KEY 3 – Then press Auto Trans. The Keyer will come off at the same time the BKGD changes. Then on the way back on just make sure the Keyer and the Background are included in the next transition.
Is there a way to set it up with out having to do that. My TD’s seem to have a problem remembering to do that part. I would like to just make it happen without them knowing.
Build custom Controls for Replay in and Replay out that will make sure to Take out the Score and then on a Replay Out put the score back in.
Can I do that with Media wipes? I had it setup like that at one point using my Blackstorm, the problem is that we would want to transition into a Video and I would lose my alpha channel.
