We are currently in a three camera system, all Sony NX5U (yes, they’re relics), feeding a Carbonite Ultra via SDI. The output from the Sony’s is supposedly 1080i/60 (59.94). However, regardless of the output combination I try I can’t keep the camera inputs from rolling even with the internal reference set to 1080i 59.94. What am I missing?
I am aware of the IO Processors and the cameras do work when set to SD-FS (which I’m still unclear on the meaning). But I would prefer to do this without processors if possible. I’m considering getting an external reference but am unsure that would solve this issue.
I have also tried the same scenario utilizing 720p output from the cameras however I’m not clear on the output frame rate there and the manual isn’t too helpful either. Any suggestions or help appreciated.
