CC Question
I’m trying to get a custom control to transition our live bug off screen. I’ve changed the transition in/out in xpression to the desired effect and can get it to transition in, but I can’t get it to transition out with the desired effect.
My custom control is set up:
CG FILE
CG LOADTOPGM
HOLD CC
TAKE CG OUT
END
What am I missing?
thank you.
What happens with the Take CG Out?
#Vision
Check your transition logic for the scene in Xpression - if you have a Scene Director specified for ‘in’ or ‘out’, the scene won’t use the sequencer’s transition settings.
#Vision
So we confirmed that in Vision there is no “Take Offline” command.
You can use the CC insert for a “macro” and then try adding this command
[COLOR=#000000][FONT=Helvetica][SIZE=12px]X\TAKEOFFLINE\\
That will work for items that are always in the sequencer with the same IDs.[/SIZE][/FONT][/COLOR]
#Vision
Sorry my fault – scroll to the bottom to find Trigger Cmd. That is the “other Macro” command :slight_smile:
#Vision
