Changing Multiple Quad Objects Attributes Simultaneously
I am trying to build off of some old NCAA brackets that I did not build. Very simple graphic with logos, rank and name. Full screen background is the bracket. They left the quads for the logos empty so that our producers can fill out the graphic via MOS Editor Program.
These quads have Texture Coords (Texture Scale especially) on each of them.
This “Texture Scale” no longer matches our updated logo folder (where the producer would pull logos from). So I need to adjust the setting.
I tried to select multiple quads at once and then change the Texture Scale - all that does is change the texture scale for the last selected quad.
Is there a way to select all the Logo Quads on my graphic and adjust the Texture Scale for all at the same time?
Don’t work harder - work smarter…
Could you set the quads to scale on material set and just make sure all the logos are the same size? OR, you could go into Visual Basic and just connect the scale or material scale of one quad to all the others. That way you would just change the scale of one and everything changes. Let me know if you want a screen grab.
