color change
it’s posible to change background shading colors, like selected or floated?
Hi Raul!
we cannot change the color of system-defined lines of the inception RO. So the floated color and break line colors are static, however, you can create custom columns that display a choice list that has custom colors attributed to it.
this can be done in the choice list section of the metadata tab in configuration. Once there, and once your choice list has been created- select colors for those choices within the list. From there you can create a column that uses those choice list colors.
I hope this helps!
Hi Raul!
Note that to create and apply custom colors in a rundown, you must be using Inception v14 or later.
Cheers,
