CONSTRAINING TEXT TO QUAD OBJECT BOUNDARIES
Hello all, I’m looking for a way to constrain my text to remain inside the boundaries of the quad object. I know there are many posts here asking the same thing. Also, Thanks to this community I was able to find help making sure the text is centered in my quad. But as my example shows, when I add more lines, my text does not remain inside the boundaries of the quad. So if I add LINE NINE (or more lines) the text needs to scale down. Is scripting the only way to accomplish this. I can’t seem to figure out a way in VL… Right now my bounding box height is 504.
Thank you.
Hi Steve
Try the attached project
Thank you Roman! This works great. Can’t wait to dig in and see if I can duplicate it. I wish XPression would implement a TEXT FIELD object so we could accomplish the same thing without scripting…
Thanks again.
