Controlling Encoder Web UI with Custompanel
Hello all,
We are integrating a few Osprey rtmp encoders into our system that are controlled by a web ui. These are not the OG card type so not controlled natively through dashboard. I should also mention that the web ui requires authentication.
Is it possible to create a custom panel with buttons that can start/stop the encoder stream from the encoders web ui?
