I know I have done this before in training but have not had a need to do so since. I have a 2 box setup with a camera shot and CG. I would like to come back to the camera shot using a DVE transition to bring that box fullscreen. I am just blanking on how you set it up.
You’ll need to use an effect dissolve for that. The quickest way to do it is:
recall the memory that provides the boxes
turn off the key that shows the CG
reset the key that the camera shot is in to make it full screen again (just press the “Reset Key” button on the multipurpose button area - top left of panel)
set your memory to store as Effect Dissolve (even set a transition time in there too; easiest to do this in Dashboard)
save the memory
Then, you can recall the 2 box memory, then recall this new memory, and it should move to full screen. That’s provided you have recall set to “Memory” or “Effects Dissolve”.
