Dashboard Acuity Aux Control
I am looking to create buttons in Dashboard to control an Aux and AuxKey on our Acuity. We currently have an AuxKey Bus setup as an Aux Mix Key and are able to to turn a single key on that particular Aux. I would like to create a Dashboard button to turn that key on and off. Our current workaround is to simply create a Custom Control to do this and then have Dashboard run the CC. I would like to try and figure out the script to have Dashboard just turn the key on and off without having to utilize CC’s. I am thinking a simply “Key On” and “Key Off” push buttons. As a bonus, would love to have an Auto Trans Dashboard button also to transition between the BackGround and Preset buses of that Aux.
Hello Zach,
sorry for the delayed response. Could you please provide a copy of your current panel?
Best regards,
Hello Zach,
after some further investigation and talking with the Acuity team, I’ve learned that there is no transition or keyer control of AuxKey over RossTalk. Only sources can be controlled.
The workaround you put in place using CC’s is currently the best approach.
Best regards,
Marc-André Parent
#Acuity
Thank you for looking into it and for the assistance.
