Dashboard - Carbonite Panel
I am using Dashboard Panel for the Carbonite Black Plus, and I am trying to figure out if there is a way to have the selected ME show the correct inputs on the Bus layer. It shows the correct state of On Air and Not On Air (The Preview and Program buttons) on the Bus layer, but the wording for the specific inputs do not switch.
The attached picture is the inputs for MiniME 1, however, ME 3 is selected and the state of the On Air and Not On Air follows with the correct ME (ME 3).
Ultimately, is there a way to have the correct inputs show on the Bus layer when you select a different ME? If not, how do you change the Virtual Panel to only hold my ME 3 inputs on the Bus layer?
I am having a hard time understanding what you’re asking – Are you trying to “re-map” the panel so you can assign the buttons on the panel? If yes that is on the upper left you select Menu - Config - Next - Bus Map
Here is a video that show using it – if you jump to the 55:30 second time frame you will find the specifics about Bus Maps.
https://www.rossvideo.com/gallery/softpanel-introduction/
