Dashboard Legacy Version
I have an older Carbonite Mosaic based on the Carbonite Black frame. It doesn’t work well with the latest iterations of Dashboard. After an unspecified amount of time, the Configuration tab will just go blank and the only thing that fixes it is to power down the frame and start it back up, which is a major inconvenience. We recently had a Carbonite commissioner come for something else, and he said it’s doing that because it only works with older Dashboard versions. So can I get a legacy version of Dashboard somewhere? Maybe version 9.2ish? Or even something in the later end of version 8?
I am attaching 9.0.2 release (Windows x64). Please let me know if you need it for any other OS.
Kashif
Hi Brian,
Can you share the version of DashBoard and the operating system you were using when you encountered this?
