I am a new to learn Expression and Dashboard ,but there‘s only a few tutoriall on the website,can‘t satisfy my needs。I want to use Dashboard contrl Expression and Carbonite Black。Can I get some Dashboard demo of the Electronic sports?such as the ESL one。
And,I found I can‘t type chinese word into the dashboard,what can I do to fix it?
You can find a list of the most common commands inside of Visual Logic. [LIST=1]
Create a Custom Panel
Add a button to the custom panel
Add a task to the custom panel
Add a device to the task (green “+” icon on the left side of the page)
Use the “Create Parameter” option for the IP Address
Select “ok” and expand the “API” node in the tree.
Here is a basic example of a panel that can run a custom control or perform a transition on an ME:
-1145302
7788
params.getValue('MyCarbonite_IPAddress', 0)
true
Carbonite
/*! block id=1004 !*/
rosstalk.sendMessage(params.getValue('MyCarbonite_IPAddress', 0), 7788, "MEAUTO ME:" + 1);
/*!!9641aec170b7ac6cdd2ee7db9b48b11d!!*/
/*! block id=1005 !*/
rosstalk.sendMessage(params.getValue('MyCarbonite_IPAddress', 0), 7788, "CC " + 1 + ":" + 1);
/*!!b2aa5fb5f2c39ce13ff11c57accbed2c!!*/
