Data delay display
It’s not about delaying the data, it’s about delaying the display
For example, if the data transmitted is 2, I want it to be updated to 2 after 5 seconds.
Trigger a scene-director that has a 5 second pause in it before it displays the data
Yes. What was said above. - You go into the text object that is going to update, or just a dummy one. Then there, there is a script item for “OnSetText”. And so when the text changes it will do whatever you put into the script. In this case, you can want the text to change. So I would have the text, then I would have a dummy text. When the text changes, a scene director runs to update the text, but 5 seconds later, on the dummy text. That way the source data is never actually the text that is online.
