Any Help
You need to install excel.
If you have and it still does not work follow this link;
Although the driver link seems to be dead so try this link;
https://www.microsoft.com/en-us/download/details.aspx?id=54920
Its installed!!!
Thank you so much for the exclamation points however did you try installing the 32bit driver as I explained?
Thanks simon I installed the 32bit and its work now
No problem, pleased it worked.
