Is there a way to have the Datalinq Key’s value change based off of a text object? I’ve attached a screenshot to help explain what I’m talking about.
Check this forum post: https://discussions.rossvideo.com/forum/default-forum-gc1/xpression-cg-and-graphics-system-gc12/17238-use-text-object-instead-of-datalinq-key-with-datalinq
The next next release of XPression, probably version 9, and probably sometime between April-August, will allow this to be done without scripting.
Thank you so much! Worked like a charm. Can’t wait for that new addition to version 9.
To bump this… I’ve got Xpression 10, I don’t see this feature. Nor can I seem to figure out how to do it with scripting, which I am hoping to avoid anyways if this feature was actually added. Where can it be found?
Right-click in the field and choose a text object.
Or you can just write @textobjectname@
Just put the text object name between “@”
Thanks. I have it working now… although, it isn’t quite working correctly. I have my hidden Datalinq Key visible and I can see that it does change when I change the parameter in Dashboard… however, the name that I have linked to the Datalinq Key seems to only update every other time.
So if I change the parameter in Dashboard and take the scene, it is still the old name (though I can see the parameter number has changed). If I take it offline and then on again, only then will the name have updated too.
If I try to change it live, I can see that the hidden Datalinq Key number changes as I change it in Dashboard, but the name only changes every second time… and to the previous name that it didn’t load when the change was made.
Great, that worked. Still only changes every 2nd time if the graphic is live, but I don’t think we would need to change it live on-air (though it would be nice if it did work, just in case!)
It should change, is live update ticked as well?
I had to check “requery scene” on the Datalinq Key as well. Thought I didn’t have to since that one was updating fine. Now that I’ve got that checked off on both of them, it is updating live. Thanks for the help! This is neat stuff!
No worries, pleased you got it working ![]()
