Proper head scratcher here. We have up until recently been running 3 Cambot 520PT heads via Smartshell. It’s a single PC Smartshell installation, no separate server. We also have a router (3G 144) and an NK-IPS directly connected via T-Bus to two NK-, an NK-GPS and an NK-VRC. We also have several RCP-ME panels, connected to our local broadcast network, to which the NK-IPS is also connected.
The problem arose when we disconnected the Cambots from the network, the RCP-ME panels slow down in operation and the Macros we fire from them stop working. This happened before when we moved the Cambots and Smartshell onto a separate network in order to try to stop disconnection problems, we had to put them back on the network.
I have it at the point now where the system is fine if only the three Cambot heads are powered and on the network. Smartshell and the associated PC are also off.
Not having been involved with the installation here I can only speculate as to what might be going on. It seems that disconnecting the 3 robot heads (or indeed, only 1 of them) causes something on the network to panic and start flooding the network trying to find them.
There was a thumbnail server running, which switched a matrix destination, however we were told by Ross that this had been disabled a while back (again, while chasing the connection dropping problems we had).
If anyone has any pointers as to what part of what config needs changing, we would be very grateful, else we are stuck with a pile of robot heads keeping our network calm.
Andrew.
