Displaying Switcher Parameters inside a Dashboard Panel
Hey there! I want to build a Dashboard panel that displays a ton of different pieces of information about a Ultra Carbonite 60 switcher. Specifically I want to know the sources inside every bus (ME preset and background, keyer sources, auxes etc), and DVE Parameters so that I don’t have to dig through the Live Assist menus to check this information whenever I make changes. I have the Carbonite connected in Dashboard and added as a Data Source in the panel, but can’t figure out what I need to do next to display this information. Ideally it would just be some text that changes whenever a CC, Memory or I change the source of a bus or the DVE updates. I was able to find the correct parameters for the DVEs, and could see those updating.
Thanks for the help!
Will respond in the other thread.
as a first time poster you needed to be approved (spam bot stuff)
