I want the drag label to be in the format shown in the figure below. I want two different DRAG objects to assign different values to the drop object, and instead of writing two ogScript tags, I want to be able to identify the specific DRAG object ID and return different values between “drag” and “drop”. Is there an event that does this?
PS: The event attribute in dashboard is not found in the help document where I should look for it.
