We are setting up a dual box for our newscast. The cutout in the graphic is not 16:9, but the video is.
When we put the DVE keys in under the graphic, one DVE box (key 4) overlaps the other DVE box (key 3). Is there a way to set a hard limit on the edge of the DVE key?
Yes indeed, you can adjust DVE crops to match your graphic and when the composition is saved the setup will be retained for recall.
To get to crops press the key selector that the DVE is assigned to which will bring up the DVE menu, then press Next - Next and you will see the Crops menu, here you can make the necessary adjustments. You can also set this via DashBoard LiveAssist.
Nigel
