Dynamic Material, Visual Logic, Datalinq ( Excel ) and Datalinq Key
I’m trying to combine Dynamic Material, Visual Logic, Datalinq ( Excel ) and Datalinq Key but unfortunately the material is not refreshing.
When I do it straight using a value to adress @MyTextObject@ it’s working fine and when I do the same using Visual Logic it’s working fine too.
Visual Logic is responding the way it should but for some reason when I’m using the Datalinq I got an issue.
Regards
It might be a mixture of when each of those refreshes (notoriously, Visual Logic is the last thing to refresh AFTER dynamic materials and Datalinq.
You could try adding the Scene.RefreshDynamicMaterials line of script to your OnPreviewRender and OnBeforeOnline events within the Scene object.
when using macros to complete paths or dynamic materials anything like that if the macro is coming dartalinq you need this checked.
