Dynamic ROSSTALK IP
How do i set up a Rosstalk input on the acuity with an IP that is always changing. My laptop is always with me, and ill be at different locations and need to send Rosstalk to the switcher from different subnets and IPs.
Your IP should not matter. Your sending to the Switcher and its IP should stay the same.
If your building custom panels you can always use the internal hosts table so that you assign a device to all the functions not an IP address each time.
Then your able to edit the host table in the custom panel to the new IP addr as of the switcher.
#Acuity
You do have to enable a RossTalk device on an Acuity Panel Port
#Acuity
