Export PNG From Xpression ENPS Plugin?
We recently updated our ENPS Xpression plugin to Version 12.0.5977
We noticed that users are no longer able to right click on the preview and export as PNG. Was this feature removed or is there a way to make this possible again?
Thank you!
Chuck
Did you also switch from the ActiveX to the HTML5 plugin?
Yes
If you click on the 3 dot menu you will find the “export current frame to file” feature:
Perfect! Thank you Garner for the help!
Chuck
