getIdentifiedConstraint
Hi
I am trying to use getIdentifiedConstraint and getConstraint to get information about the constraints of a parameter. The ogScript-documentation is very scarce on information about these functions.
To take my problem for instance:
I have a integer-parameter with several constraints. It looks like this:
Value: 1 Name: abc
Value: 2 Name: xyz
I know the value I need to find within these constraints. What I am looking for is the “Name” of that value. I would think like this, but of course it doesn’t work:
var value = this.getValue(); // Don’t worry about how I know this
var allMyChoices = params.getConstraint (0x15);
var MySingeChoice = allMyChoices.getIdentifiedConstraint (value);
var myName = MySingleChoice.getValueAsString();
I know it may be hard to understand what I am trying to accomplish here, but a brief overview of how the constraint-scripting works would be appreciated :slight_smile:
var myStringValue = this.getValueAsString(); //Okay, but did you know you could just do this?
//If you’re still curious, here’s the answer to your question
var allMyChoices = params.getConstraint(0x15);
var myChoiceName = allMyChoices.getStringOf(value);
You can also get the full list of choices with:
var choices = allMyChoices.getChoices();
for (var i = 0; i < choices.length; i++)
ogscript.debug(choices[i].getValue() + ’ = ’ + choices[i].getName());
