Hello -
I have a Ross Graphite (1080p59.94 External NTSC Locked) with Carbonite and Xpression. Within Dashboard, I set Outputs (Internal - XPIn1V/A and XPIn2V/A) to be AUX 1 and AUX 2, respectively. Coming out of the Carbonite to ME/elsewhere, the AUX is fine. In Xpression, “Graphite Graphite” is initialized, and the status is “External, Locked”. For the “Graphite Graphite” in Xpression: Input Channels 1-4, I have messed with different Buffers and Sync on frame settings. However, the input that goes out of the Xpression using these live sources is glitchy, but not on the Virtual Output. (Video attached - Left box is in 1 and right box is in 2 (this one glitches about 4 seconds into the video)). Inputs 1/2 seem better than 3/4 but still freak out occasionally.
