Head Selection in save file or salvo
When creating a Salvo on an production I save all routing points, so also all routings to my multiviewers pips.
But would there also be a posibility to include the head selection in Ultriscape in some way?
For some productions I do select other multiviewer setups on a multiviewer head. When loading an production it would be really nice to automatically select the saved multivewers.
Kind regards,
Hylke Wolfkamp
I think this is what you are asking for. The place you have to start off is by making your Layouts as a Source in the Ultrix. See attached Picture Below.
Now that you have a Layout source to take for your Multi Viewer, you can make your Salvo! The next Picture shows how you can take your newly made source and put it into the Multivewer. (The top row is the source that you just made for your different layouts)
Then from there you can continue in that Salvo to load your Sources into the individual PiPs within your layout. Below is that picture.
Hope this is what you were looking for!
Hello Michael,
Thanks for the reply! This looks exactly what I was looking for. I’ll test it soon.
