Help with finding an old post
Hi! I need help finding an old post from around 2018 or 2019. It was in a Dashboard thread. It was a brilliant piece of code, I think the authors name was Bill, but I’m not 100% sure. It contained code for getting text from a data table and sending it to text fields.
The panel had a data table with 3 fields Number, Player and Jersey. It then had a drop down list that contained the data from the table formatted like this:
1 - Brian Yankees when you selected from the drop down, the same data would appear in 3 separate text fields of the same data.
You could edit the text in the table. You could also add a row, delete a row using buttons. One last button would update the drop down.
I hope I’m making sense here. I had downloaded the panel/code and it has worked beautifully for me. I was also able to go into the code and modify it for whatever I needed it for. I had 5 different versions of it.
The server where this data was stored crashed and all my custom panels got wiped out. I now have to create everything from scratch and this particular panel/code was pretty much the center of all the panels.
Thanks in advance for your help
Well… I dont know where that old post is.
But I have posted similar posts (or maybe on the same post for that matter) about the same matter some time ago.
I use the same method in alot of tables on my own projects, and figured I could allways use some freshening up on my skills.
So here you go!
true --- 1 - Player 1 2 - Player 2 3 - Player 3 tableIndex var x = params.getElementCount('tableInfo');
var newPlayer = {
num: ‘’,
player: ‘’,
jersey: ‘’
params.setValue(‘tableInfo’, x, newPlayer);
var i = params.getValue(‘tableIndex’, 0);
var x = params.getElementCount(‘tableInfo’);
if (x > 1) {
params.getParam(‘tableInfo’, i).remove();
params.setValue(‘tableIndex’, 0, i-1);
} else {
var newPlayer = {
“num”: “”,
“player”: “”,
“jersey”: “”,
params.setValue(‘tableInfo’, 0, newPlayer);
params.setValue(‘tableIndex’, 0, 0);
var players = [‘—’];
for (var i = 0; i < x; i++) {
var player = params.getValue(‘tableInfo.’ + i + ‘.num’, 0) + ’ - ’ + params.getValue(‘tableInfo.’ + i + ‘.player’, 0);
players.push(player);
var x = players.length;
var cArray = ;
cArray.push({key:i,value:players[i]});
var choiceConstraint = params.createIntChoiceConstraint(cArray);
params.replaceConstraint(‘playersDropdown’, choiceConstraint);
params.setValue(‘playersDropdown’, 0, 0);
var sel = params.getValueAsString('playersDropdown', 0); var num = ''; var player = ''; var jersey = '';
if(sel != ‘—’) {
var check = sel.substr(0,sel.indexOf(’ '));
if(params.getValue(‘tableInfo.’ + i + ‘.num’, 0) == check) {
num = params.getValue(‘tableInfo.’ + i + ‘.num’, 0);
player = params.getValue(‘tableInfo.’ + i + ‘.player’, 0);
jersey = params.getValue(‘tableInfo.’ + i + ‘.jersey’, 0);
break;
params.setValue(‘playerNum’, 0, num);
params.setValue(‘playerPlayer’, 0, player);
params.setValue(‘playerJersey’, 0, jersey);
That should do the trick if I didnt misunderstand you.
Warning: It does require that the # (number) field is unique, as the selection in the dropdown will choose the first occurance of the number in the dropdown.
Thank you so much Aleksander! This is perfect and works just the way the older version worked. You don’t know how much extra work you saved me! Thank you again!
