Hold Button on Touchscreen Display
I don’t know how but I noticed today that the hold button on the top display is locked and we can no longer copy anything up to it or do anything on the top display. I would have thought that it was just a toggle on off, but it doesn’t do anything when you push the button…does anyone know how to unlock the top display screen? Any suggestions would be helpful…the manual was not that helpful…
Sounds like it is in a weird state.
You could restart the panel application. In the positioner area hold down the three buttons Hold Link Clear and then press the button on top of the positioner.
This will restart the panel application. Takes about 3-5 seconds and you should then be fine. This has no impact on the frame or what is on air will not change.
#Vision
That did it, thanks a lot!
#Vision
