I have struct tables in a widget, and I want them to use an internal param for “w.selectionparam”
Is this possible? I’ve tried to use normal and relative parameters.
I also tried using one of the global params, but it doesn’t seem to work.
The struct table is in the widget, the global param is well, global.
I must be doing something wrong
Ok, I figured it out: “w.localselection” was preventing “w.selectionparam” from working.
