Hello
How can I create a tournament bracket graphic on XPression? The 2024 CUSA Volleyball tournament will be held in 3 weeks and am curious to know how I can create one to use as a preview with the tournament approaching and during the tournament.
Hello
The background would be easy to duplicate from any of the NCAA brackets. As far as the teams, I would make a global list of all the participating teams, including “bye” and a blank. In each position on the bracket have a text object that is published and linked to the global list using a pull-down. If I am over simplifying, then give me a little more info.
Hi Victor,
Is this for your ESPN+ broadcasts? There should be a set of scenes in the 2024 Olympic Sports project under the Brackets category in the scene manager. Find the one that best works for the CUSA format (might need to change the Layout option on the Take Item once you drag the scene into your sequencer) and you can just fill out the info in the Template Data area.
Hi Jeff
Ahh ok I see. I thought I had to create a whole graphic from scratch. Thank you so much for the information. I sure do appreciate it!
Hi Malcolm.
Yeah, apparently there are tournament brackets in the 2024 olympic sport project and I wasn’t aware of it. I got it covered! I appreciate the help!
