Hi everyone,
There is a primitive called LINES in xpression. How can i manuplate the x, y & z numbers of the ‘points’ inside the lines thru external data? in other words how can i control the x, y & z numbers externally thru datalinq?
Gaurav
Hi everyone,
Gaurav
Yes you will find references in the SDK how to control them.
I have an example here that animates, I cannot give you the project as it belongs to a client but here is a script I wrote.
OnOnline
dim Lines1, Lines2 as xpLinesObject
dim count, tally as xpTextObject
self.GetObjectByName(“Lines1”, Lines1)
self.GetObjectByName(“Lines2”, Lines2)
self.GetObjectByName(“Tally”, tally)
tally.Text = “1”
Lines1.SetCurrentList(0)
Lines1.ClearCurrentList
Lines2.SetCurrentList(0)
Lines2.ClearCurrentList
this was on a Scene Director script
dim count as xpTextObject
scene.GetObjectByName(“Lines1”, Lines1)
scene.GetObjectByName(“Lines2”, Lines2)
scene.GetObjectByName(“Count”, count)
dim c as integer = count.Text
dim tPoint, ctPoint as xpTextObject
dim x as integer = 1180 / c
dim y as integer = 10
Lines1.BeginUpdate()
Lines1.AddPoint(0, 1000, 0, 5)
dim i as integer
for i = 1 to c
scene.GetObjectByName(“tTicket” & i, tPoint)
dim t as integer = tPoint.Text
engine.DebugMessage(tPoint.Text, 0)
Lines1.AddPoint(ix, ty, 0, 5)
Next
'Lines1.AddPoint((c+1)*x, 0, 0, 5)
Lines1.EndUpdate()
Lines2.BeginUpdate()
Lines2.AddPoint(0, 1000, 0, 5)
for i = 1 to c
scene.GetObjectByName(“ctTicket” & i, ctPoint)
dim t as integer = ctPoint.Text
Lines2.AddPoint(ix, ty, 0, 5)
Next
'Lines2.AddPoint((c+1)*x, 0, 0, 5)
Lines2.EndUpdate()
Thanks Simon, will work on it and get back if i am facing any issues.
