Keyframe move in Vision
I want to take a camera shot full screen then on command like a custom control make a DVE transition and have the camera shot be sized down into a webpage. I know how to size the camera shot but I don’t know how to have it transition with a custom control. Any help would be great.
just recall a memory using effects dissolve or build a DVE sequence that does it. I would make a memory first that sets up the Keyer to be in Preview – unless you have an available ME that is no on air – In that case I would just Recall the Keyer to the PGM side of the ME full over the BKGD. Then in the next Memory have the Box sized down the way you like it just make the attributes set so that it does not change the source in the Keyer. Then you can make a custom control that Recalls the first memory, selects the ME Re-entry as the source on your PST BUS (of the PGM ME) then Holds. This will allow you to then select the Key source you would like. Then you can cut the ME on air (or make the Auto trans / Cut command in the CC followed by another Hold) when your ready for the Squeeze back you just press it again so that your last command in the macro is then next Memory Recall.
#Vision
You’ll need to build a sequence first.
-Go to your sequence editor
-Clear work space
-With your camera keyer full, insert a key fame
-Squeeze your camera down
-Insert another keyframe
-Save sequence
With sequence selected as the transition type, hitting auto transition will run the sequence
From there you could just save a memory with your sequence selected on the keyer and use auto transition to run it.
#Vision
Thanks for your help! I got it worked out.
#Vision
