I have Kipro units and K2 Units all on the same network with the switcher. Is there a way to do Clip Store on the Switcher?
Example: If i have a videos in K2. Can i fire a macro on the switcher to pick a clip and play the clip.
Thanks for any help.
The K2s support the AMP Server Protocol.
You can setup the device using AMP and then be able to assign Clips and cue them.
http://www.rossvideo.com/pdf/cutsheets/acuity-interface/Video-Server_GVG(4820DR-670).pdf
That link will show you how to configure the device.
Here is a link that has a video for working with Clips and even animated transitions on Vision (same workflow applies to Acuity).
By the way is this a single panel or multiple panel workflow? Where is this switcher located?
Is there anything i have to do to get the VTR to work. Its not letting me set that up.
