We have a 3 channel XPression studio in our truck and XPression Designer in our studio with our with our Carbonite Solo All-In-One. we tried to load one of our truck projects in the XPression Designer and it didn’t work. Didn’t give us any specific errors other than a fail message. Is possible to import from our 3 channel machine to Designer? If it is possible, is there anything we should be looking at on the truck projcet that might cause issues in the studio? Thanks.
Do they match version numbers, i.e 10.5.xxxx ?
I will have to fire up the unit in the truck to double check. I’m guessing from your question is differing versions could be stumbling block #1?
Bill Brown
Regional Video Engineer|
W: 515-697-6633 | C: 515-669-1903
2205 Ingersoll Ave, Des Moines, IA 50312
P Go Green! Please print this email only when necessary. Thank you for helping Mediacom be environmentally responsible.
THIS E-MAIL AND ANY ATTACHMENTS ARE CONFIDENTIAL AND MAY BE PROTECTED BY LEGAL PRIVILEGE
If you are not the intended recipient, any disclosure, copying, distribution or use of this e-mail or any attachment is prohibited. If you have received this e-mail in error, please notify us immediately by returning it to the sender and delete this message and its attachment from your system. Thank you for your cooperation.
most likely causes yeah, if studio is newer than the designer.
Also quite common for issues like this to be caused by trying to load project files directly from USB - ideally they should be copied to local disk.
Also make sure you are exporting from Studio correctly. Either by exporting as an XPP or creating a Zip archive of the project directory.
