Hello, I have a problem here, I’m trying loop a scene that has a two different taglines, the first tagline animates in and hold for 15seconds then animates out, the second tagline text follows by animating in and also hold for 15seconds then animates out, this should be a continuous loop until taken offline, I tried approaching it using two different scenes and using scene triggers but I still fail, any idea of how I can solve this would be of great help. Thank you.
does everything else look the the same apart from the tagline?
Just put the first tagline and second tagline on one scene director and loop?
Yes everything looks the same except the tagline texts, I have them in one scene, how do I loop the animation? I’m still new into scripting, I don’t know much about.
No need to script.
Right click and put an event on scene director.
here you can set where it loops to and from etc.
Thank you Simon, will give that a try and give feedback.
It worked like a charm
, thank you once again Simon.
You are welcome.
