Maintain Aspect Ratio Mode in API
Does anyone know if this function of the Quad Options is accessible in the 10.5 API? I don’t see it anywhere in the official documentation but I suspect its possible with SetObjectPropertyString catch-all method. Does anyone happen to know what this is officially called in the back-end?
Hey man, I was just looking through the SDK for you, I found the value to turn it off and on.
Under xpQuadObject
Haven’t found the mode for this yet.
I’ve got that one figured out, I was more curious on the “mode” selector underneath, if there was any enumeration not in the SDK to help change that via API. Every other part of that menu is workable through the API but I have not found anything referencing the “mode” by which to maintain the aspect ratio in the API.
I can’t see anything in there myself, @Garner Millward might know. ​
​the ApsectMode property was implemented in 10.7 beta and 11.0
Thanks Brandon, good to know, I’m still on 10.5 so that makes sense I couldn’t find it.
Nick is it possible for you to upgrade at this time? ​
I can upgrade my Developer PC but unfortunately we are not likely to be able to upgrade all 15 or so of our Studio XPressions and 10 Designers at this time so I’ll likely be figuring out a way to match the scale I’m attempting using the material transform properties instead of the best-fit system.
