I am trying to send a simple play command to the Mira from the ultra using custom control. I have put the Mira 422 under amp and put in the port and IP. I can’t seem to get it to play the clip on the mira. Any suggestion would be great.
Hi Jim,
On the Carbonite Ultra, did you assign the Mira device to its video input? (DashBoard>Configuration>Inputs) This is also where you can assign the Mira’s channel number to the video input.
